lacrits68 Posted July 31, 2012 Share Posted July 31, 2012 hello! I wonder if you could help me with som input in my problem? My disco 1 3,9 1998my have an "popping" sound when idle....its like having some nuts in carbore box....a soft, non metallic sound...sound seems to come from back of the engine, on drivers side. "popping" sound come when engine gets warm! Cold engine runs just fine! when driving and giving engine lots of right foot it becomes kind of "chirping" noise! This nois appears only when loading engine. idle is "hunting" 800/+-100rpm a bit! No coolant loss or any other problems either! What might be wrong? cheers Jan ____ Quote Link to comment Share on other sites More sharing options...
teabag Posted August 2, 2012 Share Posted August 2, 2012 Maybe a blown manifold to Y pipe gasket if the sound is loudest under load, they are difficult to check as they can blow at the rear ie. facing the block. Quote Link to comment Share on other sites More sharing options...
lacrits68 Posted August 3, 2012 Author Share Posted August 3, 2012 Hello! After lots of listening i seems that that sound comes aroun starter motor! Cant realy pinpoint "the point" but it feels most when touching starter motor! Any ideas before tearing it loss? //Jan Quote Link to comment Share on other sites More sharing options...
ian_s Posted August 4, 2012 Share Posted August 4, 2012 sounds like the exhaust gaskets to me too. take the manifold off and replace all of the gaskets, its not a difficult or expensive job to do Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 5, 2012 Share Posted August 5, 2012 Use quality composite gaskets, none of the tin rubbish! Quote Link to comment Share on other sites More sharing options...
