del Posted August 13, 2012 Share Posted August 13, 2012 Are they a good idea to cut down engine noise? Quote Link to comment Share on other sites More sharing options...
discomikey Posted August 13, 2012 Share Posted August 13, 2012 i had one, and dont know if it was just made faulty, but it held the filler cap open slightly, covering my engine in oil, it didnt seem to make much difference to be honest, although it would make one with noisey tappets a bit quieter.. although you could just adjust your tappets. best thing is to insulate the bulkhead especially the area just behind the engine and footwell sides! Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 13, 2012 Share Posted August 13, 2012 I think mine makes a difference, and it doesn't hold the cap open. Quote Link to comment Share on other sites More sharing options...
del Posted August 13, 2012 Author Share Posted August 13, 2012 I got a second hand one at billing , there seemed to be a few of them knocking about so i thought there maybe a problem with them Quote Link to comment Share on other sites More sharing options...
discomikey Posted August 13, 2012 Share Posted August 13, 2012 I think mine makes a difference, and it doesn't hold the cap open. as i say, i think the one i got had the cut out for the filler slightly wrong. it would probably fit fine if i cut it a bit more but i didnt really feel a difference with the rest of the soundproofing ive got haha, and i like the ali rocker cover and manifold anyway Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 14, 2012 Share Posted August 14, 2012 best thing is to insulate the bulkhead especially the area just behind the engine and footwell sides! I'm thinking about getting a roll of FatMat and trying to stuff it down there..... Quote Link to comment Share on other sites More sharing options...
discomikey Posted August 14, 2012 Share Posted August 14, 2012 i used kingspan, which is a noise and heat insulator, and is fire retardant, i.e. wont catch fire. (tested this with blowtorch too!) it doesent hold water either which is a bonus, and it was free for me. fatmat may be better, although the amount of difference that the kingspan made was amasing. flashing tape is also a good idea on all panels, (builders flashing tape is the same stuff as that posh car stuff but a lot cheaper) Quote Link to comment Share on other sites More sharing options...
trax Posted August 15, 2012 Share Posted August 15, 2012 Be careful with the bitumen flashing tape in the engine bay. It goes soft when warm and it doesn't have a really high flashpoint... and if you do have an engine bay fire, well it won't help . Quote Link to comment Share on other sites More sharing options...
discomikey Posted August 15, 2012 Share Posted August 15, 2012 the flashing tape is inside the cab so no worries there but thanks for the heads up Quote Link to comment Share on other sites More sharing options...
gruntus Posted August 23, 2012 Share Posted August 23, 2012 i used kingspan, which is a noise and heat insulator, and is fire retardant, i.e. wont catch fire. (tested this with blowtorch too!) it doesent hold water either which is a bonus, and it was free for me. fatmat may be better, although the amount of difference that the kingspan made was amasing. flashing tape is also a good idea on all panels, (builders flashing tape is the same stuff as that posh car stuff but a lot cheaper) Mikey is there a particular type and thickness of Kingspan you used? I would be interesetd in fixing to the underside of my bonnet. And in answer to the rubber cover I did notice a difference! I have a defender 200TDi and fitted a cover from a 200TDi Disco, this did mean removing the piece that goes over the induction chamber so that it cleared the exposed top mounted turbo. Cheers G Quote Link to comment Share on other sites More sharing options...
discomikey Posted August 23, 2012 Share Posted August 23, 2012 25mm kingspan, just the normal foiled on either side kept it away from the turbo just to be safe, silicone stuck to the bulkhead. although flashing tape in the appropriate places also makes a big difference. Quote Link to comment Share on other sites More sharing options...
