mikey7134 Posted September 5, 2012 Share Posted September 5, 2012 I know there is "axle seals" available, but wondered which ones were for which part of the axle... I've done the diff ones, But, ive got a black dusty/oily layer inside the brake drums, and also my hub caps had a small puddle of oil in (they're not supposed to are they?). Which part numbers do i want for seals to cure all these leaks.? I imagine fronts should be similar, if not the same..? Also, would you reccomend replacing bearings while im in there? They do not feel worn, but is it worth doing? Cheers Quote Link to comment Share on other sites More sharing options...
ejparrott Posted September 5, 2012 Share Posted September 5, 2012 If you've got it in bits then change the bearings. The splines should be oiled to prevent wear. There should be a felt washer at the end to seal them, and an O ring on the drive flange for the hub cap. There are seals at the back of the hub to keep the interface between hub and stub axle sealed, there are also seals in the end of the axle tube to keep axle oil and swivel oil seperate. Quote Link to comment Share on other sites More sharing options...
western Posted September 5, 2012 Share Posted September 5, 2012 S3 parts link http://www.retroanaconda.com/landrover/2010/03/series-iii-parts-book/ not mine Quote Link to comment Share on other sites More sharing options...
mikey7134 Posted September 9, 2012 Author Share Posted September 9, 2012 Cheers. Is there a filler point for hubs? Or is it fill / half fill with oil when assembling, and hope it dont leak out? I realise it may be a bad move, but am going to leave the bearings for now.. (Landy is costing enough already :/) and when they start to go i will change them. Instead of changing now and scrapping bearings which may have a lot of life left.. It has only done 50,000 miles anyway. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted September 9, 2012 Share Posted September 9, 2012 For the hubs? stuff full of grease on assembly. I'm thinking about modifying mine so I can top up the grease, rather like my trailer. Quote Link to comment Share on other sites More sharing options...
