V8david Posted October 10, 2012 Share Posted October 10, 2012 Next question, sorry... Has anyone removed/replaced the inlet manifold bypass pipe at the front of the inlet manifold? Part number ETC6547 I think? Pictures of the part suggest that it is threaded so will it simply unscrew? Is heat required? I've got a spare inlet manifold to practice on as well. Mine's rusty and leaks slightly so if I've got to take the inlet manifold off again I may as well replace it. Also, if it does screw in, does it need the thread coating with anything before screwing the new one in? Cheers again David Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted October 29, 2012 Share Posted October 29, 2012 Searching my part number brings up this; So it looks like a normal screw thread. If its steel into ali its probably stuck. You could try welding nuts to it or putting stud extractors down it. A bit of silicon or gasket paste would help it for the future? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 29, 2012 Share Posted October 29, 2012 Tried to unscrew a couple, never had much luck but never tried *very* hard. Quote Link to comment Share on other sites More sharing options...
V8david Posted October 29, 2012 Author Share Posted October 29, 2012 Thanks for the replies. I have tried pretty hard on the spare one, but not my hardest yet! Penetrating fluid and lots of heat made no difference at all, it's fookin solid quite frankly. I'm thinking it could be a job for the machine shop place when I need it in the future, once I've saved up for megasquirt. Quote Link to comment Share on other sites More sharing options...
muttleyd Posted October 29, 2012 Share Posted October 29, 2012 Have not unscrewed the pipe. But I have unscrewed the bung in its place to fit one. Plenty of penetrating lube left to soak and a big bar, and a little heat and the bung came out.easier though cos you have a hex to drive. Fitted it with a pair of pipe grips and some Ali sheet to protect it. Just some ptfe tape to seal. But could use loctite thread sealant. Quote Link to comment Share on other sites More sharing options...
