Heater control valve
jad
Hi
Has anyone fitted a control valve to the coolant circuit of the older engines (pre-tdci) to allow them to heat up quicker? Was thinking of something like the TDCI part ie http://www.brit-car.co.uk/shopimages/products/normal/JQD500080.jpeg or something off of ebay like http://www.ebay.co.uk/itm/251148276472?_trksid=p5197.c0.m619
If you have what did you fit and has it made much of an improvement? The 200 is taking quite a bit longer to heat up now its getting colder!
Cheers
Jad
I wouldn't be surprised if you could fit the old Series part to a 200Tdi, the threads for the valve and the hosetail are certainly similar anyway.
http://www.ebay.co.uk/itm/251144770191
The hosetail for the heater pipe at the back of the block on a 200Tdi uses this part:
http://www.lrseries....h=624091&page=1
I reckon you could put the Series valve in the port on the back of the head, which would allow you to control the water flow.
But I'm not convinced it's worth it. With a properly working thermostat a 200Tdi will heat up pretty quickly. On my 8 mile drive to work, mine's blowing warm 1.5 miles from home and up to temperature and hot by the 4 mile mark. And that's with a viscous fan that's somewhat stuck on!
Does anyone know if the threads are the same? Is it ok just to block the flow through the heater rather than having a bypass? Land rover thought it was worth it for the TDCI's. Im guessing it would reduce the emissions by having a faster warm up time. I havent timed how long it takes for my engine to warm up but will do next time i drive it but every little helps! Its very cold at 6 45 in the morning!
Thanks
Jad
The stat is fairly new as the last one stuck shut and chucked half the coolant out! It was a wax stat. I ordered OEM or Genuine cant remember now. The temp tends to sit at 88 in normal driving in hot weather and 82 in cold weather. Only goes up to 91 when pushing on... The rad is in very good condition, recored with an HD core and I dont run a fan.
Maybe I am just impacient in waiting for it to warm up!
I did find a thread saying the Series 3 valve was 1/2BSP but cant find what the 200 head is.
Cheers
Jad
