Dave09 Posted November 6, 2012 Share Posted November 6, 2012 Hi I'm after a digital outside temp gauge. Can anyone recommend one. thanks dave Quote Link to comment Share on other sites More sharing options...
mmgemini Posted November 6, 2012 Share Posted November 6, 2012 I have one of these http://www.spa-uk.co.uk/(S(w20g1uytr4fvyggtweadxcdn))/design/productdetails/default.aspx?objid=69 The internal sender is mounted below the instrument panel. The outside is mounted at the side of the left headlight panel. That's the wrong place. Please mount it at the bottom as where I have it the intercooler heat gets to it when stationary. Now IIRC the thread for the senser is a tapered BSP. I recut mine with a die so I could use a nut to hold it in place. HTH Quote Link to comment Share on other sites More sharing options...
Guest Posted November 6, 2012 Share Posted November 6, 2012 Depends what you want but I brought a couple of these for my Fridge, I was really impressed with them especially for the money. Jason. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted November 6, 2012 Share Posted November 6, 2012 Wow, talk about each end of a spectrum... £194 or £1. OK, £2 if you buy one for inside and one for out! Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted November 6, 2012 Share Posted November 6, 2012 Might of known Jason would be using the £1 ones! Quote Link to comment Share on other sites More sharing options...
Smego Posted November 6, 2012 Share Posted November 6, 2012 I want something I can run off the 12v with a constant backlight, used to have one on a previous car but not seen them for ages? Quote Link to comment Share on other sites More sharing options...
Guest Posted November 6, 2012 Share Posted November 6, 2012 Might of known Jason would be using the £1 ones! They work and are good !! Quote Link to comment Share on other sites More sharing options...
Guest Posted November 6, 2012 Share Posted November 6, 2012 I want something I can run off the 12v with a constant backlight, used to have one on a previous car but not seen them for ages? Something like this? Quote Link to comment Share on other sites More sharing options...
