potato head Posted November 6, 2012 Share Posted November 6, 2012 I'm pretty close to ordering a 44a stumpy R380 from Ashcrofts and have a few questions for anyone who can help? It's going onto a 200tdi which was a transplant to replace a 2.5 td which is at the mo connected to a LT77. Can I use the same clutch that's currently in as its fairly new? Also, I have a new slave cylinder that I was going to use on the LT77, can I still use this in the stumpy? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
western Posted November 6, 2012 Share Posted November 6, 2012 clutch plate/cover is common, slave cylinder on mine is FTC5072 use the short release bearing as listed here http://www.ashcroft-...d&productId=157 your existing bearing will foul & cause clutch slip, I found out the hard way, FTC5200 is about 10mm to long for the 'stumpy' R380. best friction plate is the 130 heavy duty item, it has 8 damper springs UQB000130 Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 7, 2012 Share Posted November 7, 2012 I got an alu clutch release bearing housing and bearing from Rakway racing when I did mine, its exactly the same size as a standard one, i used the standard master cyclinder, the only thing I did was to cut 10mm off the pushrod. - I'm sure it was a thread on here that I found that out too... Mav Quote Link to comment Share on other sites More sharing options...
potato head Posted November 7, 2012 Author Share Posted November 7, 2012 Thanks chaps. Just as a matter of interest, if I was to stick in a Disco R380 gear box how much would the engine mounts need to move forward to accommodate the gearbox and would I also have to re-position the gearbox mounts? Quote Link to comment Share on other sites More sharing options...
western Posted November 7, 2012 Share Posted November 7, 2012 you would have to cut the front centre of the seatbox to make space for the gear change levers or rebuild the box with Defender parts to use Defender gear levers. don't know about changing/moving mountings Quote Link to comment Share on other sites More sharing options...
potato head Posted November 7, 2012 Author Share Posted November 7, 2012 Yep, that's on the list along with mods to the exhaust, oil cooler pipes, turbo and water pipes, maybe electrics, relocation of air filter box, getting an engine hoist and rewelding the mounts. That's why I'm swinging towards a stumpy but also weighing up the £££ v agro / time. Quote Link to comment Share on other sites More sharing options...
Lars L Posted November 7, 2012 Share Posted November 7, 2012 The Ashcroft box should be delivered complete with the suitable release bearing. That was what I was told when I asked about mine some years ago. None came with the box, so someone along the line had better use for it than me... Quote Link to comment Share on other sites More sharing options...
