craigdouglaswright Posted November 6, 2012 Share Posted November 6, 2012 i have just acquired a second hand diesel Bosch pump and don't know if its 200tdi or 300tdi, it has a black plastic round piece in the top with electrical connections if this helps, can not see any number on the pump. regards craig Quote Link to comment Share on other sites More sharing options...
Green Bob Posted November 7, 2012 Share Posted November 7, 2012 The pumps are the same between 200 and 300. The only different one is the edc pump. If the pump doesn't have a physical mechanical 'throttle' arm, (ie somewhere to attach the cable) it will be an edc pump. The black plastic thing is the throttle position sensor for the egr... Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 7, 2012 Share Posted November 7, 2012 That'll probably be a 300 pump then, as that piece you describe is the TPS for the EGR. I don't think the 200 ever came with EGR. Quote Link to comment Share on other sites More sharing options...
jad Posted November 7, 2012 Share Posted November 7, 2012 I don't think the 200 ever came with EGR. Only Japanese imports I think. My brother has one. Jad Quote Link to comment Share on other sites More sharing options...
