Anyone ever had a problem fitting timing chains rv8
mikec
So heard back from Roland at acr he said the chains too short, one or two links.
Now the next problem/question is can anyone reccomended another timing set? I don't need vernier etc just a simple duplex all steel chain? Cheers
I bought my last timing chain / set from Turner engineering. Single chain and low noise cam gear... Fitted a dream.
Get back to who you got it from and get a replacement.
G
I've just fitted a Kent Cams duplex set. Fitted perfectly but it is a vernier adjusting pulley. TBH I'd was glad to have the opportunity to time the cam in properly instead of just accepting it might be right
Where did you get the Kent setup from? I did read somewhere that the vernier setups can be more trouble than there worth for the average engine
Got mine with a load of other bits (H180 cam, ARP studs, set followers) through work, we have an account with Kents.
Vernier comes with a plastic protractor in the box so you only need a dial gauge to get TDC and to show max lift on the cam follower and a bit of welding wire to make a TDC pointer. No real hassle to set it up properly but my heads were off so I measured TDC straight off of the piston
  • 2 weeks later...
