WHO4 MUD Posted December 19, 2012 Share Posted December 19, 2012 ok my sisters freelander 2 is having issuses first didnt start then it started and then it starts to judder at about 30-40 that was 6 weeks ago they took it to garage and they have cleaned the egr valve and all has been well till now it has started juddering again and also the exsaust fumes seem to be getting into the car !! no one is availible to fix it so im tempted to clean egr again and check the exsaust for a bad joint. is there any other reason that the car would judder?? its done 50 ish thousand. many thank for any help Quote Link to comment Share on other sites More sharing options...
defv890 Posted January 4, 2013 Share Posted January 4, 2013 Hi have u replaced the fuel filter ?? As could cause this Also is it auto or manual ?? Quote Link to comment Share on other sites More sharing options...
Simon_battersby Posted June 2, 2015 Share Posted June 2, 2015 Exactly the same is happening to my Freelander 2.2 auto. We had the egr and egr cooler replaced along with the fuel filter and I changed the crankshaft sensor myself. It disappeared initially after the new egr was fitted but has come back with a a vengeance so we tried the sensor and filter. Did you ever get to the bottom of the fault? Kind regards Simon Quote Link to comment Share on other sites More sharing options...
WHO4 MUD Posted June 2, 2015 Author Share Posted June 2, 2015 Hi Simon wow this was a wile ago. What happened in the end was they ended up putting two a few fuel additive bottle that you can get into the tank for cleaning the fuel rail then drive it around with higher revs so its a bit hotter so that would help clean the EGR. That was the advice given by a garage. And that was the last of if to my knowledge they haven't had any problems since. sorry I cant be any more help oh and they have a manual not auto Ben Quote Link to comment Share on other sites More sharing options...
Simon_battersby Posted June 2, 2015 Share Posted June 2, 2015 Thanks for the follow up Ben it's greatly appreciated . The cars still in the garage but to my knowledge they haven't found anything yet. I was considering having a Terraclean on the motor if all this fails thinking it might clean the fuel system out. I'm guessing this would do a pretty similar job as the cleaner.... Thsnks again Simon Quote Link to comment Share on other sites More sharing options...
Simon_battersby Posted June 7, 2015 Share Posted June 7, 2015 Well I had the Terraclean on Saturday and the judder is still there when we're going 70ish. Back to the drawing board!! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 8, 2015 Share Posted June 8, 2015 Terraclean sounds like a trade name for snake oil I'd suspect fuel system, either weak pump or clogged fuel filter or similar. EGR can certainly affect things more than you'd like (for example, stuck actuator leading to EGR being ON all the time) although sensors (MAF, MAP/boost, or even crank/cam sensor) can also do funny things. Rather than spend out on magic gunk, get a dealer to put it in the computer & check error codes & sensor readings. Quote Link to comment Share on other sites More sharing options...
Simon_battersby Posted June 9, 2015 Share Posted June 9, 2015 Initially there were codes coming up for the EGR which was replaced along with the EGR cooler, the cam sensor and fuel filter were also replaced. Although the car is still juddering it is not registering any fault codes. The Terraclean was just a way of hopefully cleaning any potential carp from inside the engine after reading the post about fuel additives. Although it didn't sort the problem it is running a lot better now it's been done. The cars going back to the dealers in two weeks for another scrutinising so hopefully they'll finally get to the bottom of it Quote Link to comment Share on other sites More sharing options...
