smokinv8 Posted January 16, 2013 Share Posted January 16, 2013 Hi Ralph, I think I need to replace my indicator arm which is causing some faults. I've found two part numbers STC439 and PRC3875 are they the same? And will they fit my 200tdi? And last question although this technically is the wrong place to ask . Do I need to remove the steering wheel to fit this? Thanks, Neil. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 16, 2013 Share Posted January 16, 2013 I don't think you don't need to remove the steering wheel, but if you have a bolt on one (can't remember if you do) it makes access so much easier! Just unscrew the plastic colum shroud and all the bits are there Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted January 16, 2013 Author Share Posted January 16, 2013 I think you're wrong Ross, let's wait till a grown up tells us Oh and I've already got it apart tonight and yes its a bolt on wheel. Sure I got to take the wheel and boss off. Quote Link to comment Share on other sites More sharing options...
western Posted January 16, 2013 Share Posted January 16, 2013 steering wheel & column surrounds have to come off, [you need this one for a 200tdi Defender] INDICATOR/HORN/HEADLAMP DIP SWITCH Part number: STC439 Applicable Models:Defender from HA455946 to VA104805 2nd number for pre 200tdi 90/110 Part number: PRC3875 Applicable Models:Defender to vin GA455945 Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted January 16, 2013 Author Share Posted January 16, 2013 Thanks very much Ralph, much appreciated. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 16, 2013 Share Posted January 16, 2013 The only thing I've had apart in there is the fog light switch, and it was a while ago. Quote Link to comment Share on other sites More sharing options...
western Posted January 16, 2013 Share Posted January 16, 2013 your welcome Neil Quote Link to comment Share on other sites More sharing options...
