discovery 3.9 v8 cutting out when warm
parrysean
hi there
can someone please help me in the right direction .I have had the head done on my v8 .After this it was pressurising the water so it went back to the garage only to find that the wrong gasket has been fitted .This has been rectified by fitting new and right gasket .Its not pressurising the water now but its ok when its cold but as soon as its warm the revs are up and down like a yoyo and in the end will just cut out .Its lpg converted as well and will tick over on lpg and rev but when you try and drive it justs cuts out again as its got no power .The garage has checked for air leaks and says there are none .If anyone can give me some guidence as to where to start i would be greatful
thanks sean
