pupstew Posted February 2, 2013 Share Posted February 2, 2013 Hi, just looking at the cross member on the rear of my 110 and thinking its about time it got a new coat of paint and a bit of rust treatment. Any guidance on a satin black paint to give excellent protection, or even ones to stay clear of..... Cheers Quote Link to comment Share on other sites More sharing options...
bluespanner Posted February 2, 2013 Share Posted February 2, 2013 Paint it with whatever looks nice, they rot from the inside. Fill the inside with oil Quote Link to comment Share on other sites More sharing options...
Boris113 Posted February 2, 2013 Share Posted February 2, 2013 This may not be the best solution, but I've had good results with it. Get a twist-knot wire cup for a grinder and attack the crossmember until all rust is removed, then apply a couple of coats of red oxide before using Combi-Color by Rust-oleum, I've used it for all manner of things and have had good results...plus its a lot cheaper than Hammerite. It goes on well by spray or brush, even in cold conditions. Finally some stone chip over the top -Schutz seems to have a good reputation. And as above, inject engine oil or waxoyl type stuff inside the chassis Quote Link to comment Share on other sites More sharing options...
Team Idris Posted February 2, 2013 Share Posted February 2, 2013 My current weapon is Genolite, which is part phosphoric acid, to change the rust to something non-reactive. Having no rust 'seeds' to re-start the process helps no end. But Genolite isn't as acidy as it used to be, so maybe apply, dry, brush, re-apply A thing that helps the rear end is internal flaps/gaurds. If the dirt cannot get to the rear steel work to build up, and stone chips are reduced from the tyres, the whole thing looks nicer for longer. Quote Link to comment Share on other sites More sharing options...
