ROGUE TROOPER Posted September 16, 2006 Share Posted September 16, 2006 Do they legaly have to be welded in? Ta Quote Link to comment Share on other sites More sharing options...
LR90 Posted September 16, 2006 Share Posted September 16, 2006 FWIW I repaired my 2A with ali plate (the panel behind the pedals) pop rivetted into the steel either side and that past MOTs year after year without Q. Quote Link to comment Share on other sites More sharing options...
Jon White Posted September 18, 2006 Share Posted September 18, 2006 I'd say passenger side you'd possibly get away with as its non structural, but drivers side you wouldnt casue the brake pedal assembly is fitted to it and it'd probbaly be MOT failure. Jon Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 18, 2006 Share Posted September 18, 2006 If there's corrosion within 30cm of suspension, vehicle body mount, or other structure, then it should fail. So within 30cm of the door pillar, which is veh structure. The plate that goes from the chassis to the back of the footwell- within 30cm of that. MOT regs don'r say if this is in a straigth line (as the spider scuttles), or following the profile of the metal. Bodged or non-welded repairs should really fail, but they don't - usually because of the testers ignorance. Les. Quote Link to comment Share on other sites More sharing options...
