Pat Posted February 10, 2013 Share Posted February 10, 2013 will the arctic heaters fit a 200tdi in a defender???if so how?? Quote Link to comment Share on other sites More sharing options...
Maverik Posted February 10, 2013 Share Posted February 10, 2013 Hello there, a bit of a leading question... have you done any reaserch yourself? My understanding of the arctic heater were as long as you had hot water then it can be fitted to anything... Mav Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2013 Share Posted February 10, 2013 if you meant the Series LR artic heater unit that sat in the centre of the cab, it probably would fit but get in the way for day to day use. have a look at PaulMc's links here http://defender110.nightmail.ru/ Quote Link to comment Share on other sites More sharing options...
Pat Posted February 10, 2013 Author Share Posted February 10, 2013 the heater box itself would fit but i was thinking of how to plumb it in as i think there was an "extra" water feed via an extra pipe on the thermostat housing on a series three but not sure if such an item exists for a 200 tdi. How is a defender winterised? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted February 10, 2013 Share Posted February 10, 2013 the heater box itself would fit but i was thinking of how to plumb it in as i think there was an "extra" water feed via an extra pipe on the thermostat housing on a series three but not sure if such an item exists for a 200 tdi. How is a defender winterised? The winterised 90/110 artic heaters get there water supply from the water pipes that supply the standard heater. Quote Link to comment Share on other sites More sharing options...
ajh Posted February 11, 2013 Share Posted February 11, 2013 How cold are you dealing with; at -30C here things were warm in the front (csw) after about 20 minutes; the main issue isn't getting heat it's having enough heat in the cooling system to warm things up. Mounting a house-current heater in the back (somewhere safe, with a cage) to pre-heat things along with a tank heater on the cooling lines to pre-heat the coolant seems to be the most effective method. If I was building from scratch I'd also put a heat exchanger into the main fuel tank as well; then the coolant heater could also prevent fuel gelling. Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2013 Share Posted February 11, 2013 the heater box itself would fit but i was thinking of how to plumb it in as i think there was an "extra" water feed via an extra pipe on the thermostat housing on a series three but not sure if such an item exists for a 200 tdi. How is a defender winterised? diagrams in the links in my reply above Quote Link to comment Share on other sites More sharing options...
