Stevie D Posted March 19, 2013 Share Posted March 19, 2013 late 95 /96 MY 300tdi disco. I'm replumbing all the hydraulics (well everything under the truck from the master cyl / bias valve back)after a mild resto. As the title says - are these more likely to be Metric as I assume or a mix? I know I've defender front calipers - the vented sort so think these are m10 x 1 - I've got a pair of the factory pipes for these, think the new ggodridge flexis are metric what about the back calipers or is it just suck it and see as I'm making up pipes checking as I go along? Suppose I should buy a mix of 3/16" unions both metric m10 x 1 & unf. What about pipe - copper or kunifer, whta lasts best on a general purpose truck - with a bit of off roading and road work towing trailers about etc. I find the copper very soft - but has the advantage of being easily shaped and bent / malipulated into position. Many thanks, Steve Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 19, 2013 Share Posted March 19, 2013 They should all be metric by then. Standard brake pipe from your local motor factors will do fine, it's not 'copper', but a copper-nickel alloy, which is what I think Kunifer is. both should outlast your truck as they aren't steel! Quote Link to comment Share on other sites More sharing options...
Dean1989 Posted March 21, 2013 Share Posted March 21, 2013 M10 x1 and u could get a stainless set of braided lines from ebay for like 40 quid that probably comes with the banjo fittings needed Quote Link to comment Share on other sites More sharing options...
Stevie D Posted March 24, 2013 Author Share Posted March 24, 2013 All sorted now cheers - most of it seems to be m10 x 1. Waiting for the kunifer piper /cupro nickel stuff - delayed in the snow lol... Quote Link to comment Share on other sites More sharing options...
