NRS91 Posted March 29, 2013 Share Posted March 29, 2013 Hey Gents (and ladies) I want to replace my main indicator bulbs and side repeater bulbs with LED replacements, was wondering if anybody knew which ones to use whilst keeping the same brightness. Also a suggestion for the correct flasher unit would be welcome. Reason for this is i want to fit the strobe flasher unit to make the indicators work as strobe lights. Quote Link to comment Share on other sites More sharing options...
teabag Posted March 29, 2013 Share Posted March 29, 2013 The flasher unit stays the same but u will need additional resistors for the front and rear LED bulbs, these are sold on ebay. The light may not be as bright, as the amber lens is a filter for for the light wavelength of the LED, U may find the orange LEDs a bit better, that is what I use in my repeaters in place of the 5w bulbs. I suggest you try a single LED bulb first as the manufacturing quality is variable. Quote Link to comment Share on other sites More sharing options...
NRS91 Posted March 29, 2013 Author Share Posted March 29, 2013 i was going to use bulbs without the resistors and fit the correct flasher relay to suit then i could use the strobe light kit to make them strobe.which LED bulbs fit directly into the disco indicators and side repeaters? Quote Link to comment Share on other sites More sharing options...
gilloverland Posted March 29, 2013 Share Posted March 29, 2013 There is no flasher unit on a TD5 discovery, the flash is controlled by a micro chip within the BCU. Quote Link to comment Share on other sites More sharing options...
Cyberprog Posted April 13, 2013 Share Posted April 13, 2013 I've toyed with this project myself, and I think you may be able to use them without resistors if you play with the settings in the BCU. I may have to buy some and try it though... Quote Link to comment Share on other sites More sharing options...
