Nigelw Posted April 1, 2013 Share Posted April 1, 2013 What is the purpose of the ladder frame above the sump an a 200Tdi and where can I get a new sump and lader frame gasket from? Bit leaky under there but I can find a sump gasket but not the one for the ladder frame thing, is there a gasket or just RTV? Lost myHaynes and feel a little bit screwed without it!!! Mechanics bible!!! Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 1, 2013 Share Posted April 1, 2013 I thought both were RTV to be honest.... The ladder frame is for strength I'm told, although I understand it was gone again by the time of the 300TDi... Quote Link to comment Share on other sites More sharing options...
western Posted April 1, 2013 Share Posted April 1, 2013 it was to increase the block strength & there isn't any gaskets you need STC611 hylomar 2000 sealant for the ladder frame to block joint & ladder frame to sump joint. 300tdi block is totally different design & doesn't have a seperate ladder frame. the gasket you've seen is for the older n/a & TD diesel engines. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 1, 2013 Share Posted April 1, 2013 Having rebuilt my 200tdi 6 months or so ago, i have just used a nice, thick run of black silicone. I used one of the loctite products and the sump and ladder frame are both bone dry. As said, the ladder frame is there to give the block additional strength, the 200 block is very very similar to the 2.5 na and TD blocks used in the 90/110/130 from way back when. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted April 2, 2013 Author Share Posted April 2, 2013 Perfect gents, Yeah you're right Ralph, the gasket set was for a TD 2.5, managed to find it's way in to my search results, better buy me a few new tubes and find as many and more of the gaskets and seals to try and stop this thing leaking more oil than it drinks diesel. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 2, 2013 Share Posted April 2, 2013 Loctite 5910 I use, use it for all the water way joints, all the oil way joints, use it to seal the machines at work aswell. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 2, 2013 Share Posted April 2, 2013 Loctite 5910 I use, use it for all the water way joints, all the oil way joints, use it to seal the machines at work aswell. Pretty sure thats what i used during the rebuild... Do you use it because you get it cheap from work? Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 2, 2013 Share Posted April 2, 2013 Only if I've ballsed up and not got any...Halfords stock it... Quote Link to comment Share on other sites More sharing options...
