Add cruise control to 2001 TD4?
FridgeFreezer
Now I'm doing a few miles I'm wondering if it's possible to add cruise control to my freebie. In theory it should be easy enough - the TD4 is fly-by-wire anyway and being a FL it has the relevant sensors for the ABS/HDC/TC too. The optimist in me hopes it's just a question of adding some buttons to the steering wheel...
I've looked in RAVE, and it's not clear what applies to which models - the petrol ones need vacuum actuators for the throttle and the ECU list (groan) mentions a Cruise Control interface ECU and a Cruise Control control ECU, but not which vehicles they apply to (and RAVE is a bit shady with the transition from pre-TD4 era to post-TD4 era parts at the best of times).
The parts book lists the steering wheel buttons, but also a dashboard button (cruise control by the heater controls, only LR...)
So, can anyone confirm or deny what the cruise control setup on a 1st-gen TD4 would be, and how hard it is to set up?
I'm not averse to spending £50 on an ECU and some switches from a breakers but don't want to be piddling around installing wiring harnesses and hooking up main dealer computers.
And I'm aware there are aftermarket kits, but they're ugly and they smell.
  • 3 months later...
thats interesting id i like cruise control
