bluespanner Posted April 11, 2013 Share Posted April 11, 2013 Will 5w30 fully synthetic oil be ok in a low mileage 200tdi? Thanks all Quote Link to comment Share on other sites More sharing options...
Maverik Posted April 11, 2013 Share Posted April 11, 2013 I wouldn't use anything below 10w40 on a 200 or 300tdi. IMHO. Mav Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 11, 2013 Share Posted April 11, 2013 5w40 would be fine IMO, but a 30 weight is probably too thin. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted April 11, 2013 Share Posted April 11, 2013 Will 5w30 fully synthetic oil be ok in a low mileage 200tdi?Thanks all What is your ambient temperature range? Must admit unless you're in the Arctic I'd be going for a 10W40. Also, what's been in there before? Switching to a high-detergency oil in an engine that's not had such an oil in it previously can be a recipe for oil-burning and gasket/oilseal leaks. The other consideration is the oil-spec itself: is it rated for turbodiesels? I wouldn't use anything that is not API CH-4 rated. Quote Link to comment Share on other sites More sharing options...
bluespanner Posted April 12, 2013 Author Share Posted April 12, 2013 I'm in the midlands so ambient is I dunno, -10 to 25 degrees Celsius. The oil I have is some GM stuff that Arnold Clark are knocking out for £2 a litre (£40 for four 5 litre cans) when you buy a service kit. It says 5w30 dexos2 api sm/cf I'll see what else I can get in 10w40 I think. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 12, 2013 Share Posted April 12, 2013 GM also do a own brand 10w40 thats usually very cheap. Quote Link to comment Share on other sites More sharing options...
