reb78 Posted June 3, 2013 Share Posted June 3, 2013 I have an annoying coolant leak on the TD5 from the core plug that is hidden away behind the exhaust manifold. I just have a couple of questions.... 1. This plug looks like it screws in - do you replace it completely, try tightening it a little, or remove it, clean it up and replace?? 2. I suppose i need to remove the exhaust manifold for better access. Apart from the manifold gasket and fresh antifreeze, are there any other gaskets and parts i might need whilst doing the job? Any tips or other advice would be great. Thanks! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 3, 2013 Share Posted June 3, 2013 Plugs like that I would normally remove, clean up the threads, hylomar it and refit. Quote Link to comment Share on other sites More sharing options...
defv890 Posted June 4, 2013 Share Posted June 4, 2013 We (dealer )would fit new plug as comes with thread sealer already on it and I would recommend fitting new exhaust studs and nuts as u have it off anyway. Also check its not bent also If so get it skimmed some take the webbing off as well. Quote Link to comment Share on other sites More sharing options...
