matfield Posted June 5, 2013 Share Posted June 5, 2013 So... was told today that someone had put a 200tdi disc braked discovery axle onto a 110 with drums, it fit, with some small spacers (not sure where they were as I didn't have that long to ask questions) I'm wondering whats the main differences, is it just that the salisbury axle casing is stronger or are there different diffs in there? Thanks in advance Mat Quote Link to comment Share on other sites More sharing options...
western Posted June 5, 2013 Share Posted June 5, 2013 Don't use a Disco axle on a 110, it's not rated for the 110's max weight, thats why LR used the stronger Salisbury, you can use Disco/RRC rear calipers & discs to do a brake conversion though & seperate caliper brackets if you can find a pair. I've recently done a rear drum salisbury to disc conversion & landy_novice is doing a similar job using Defender 300tdi rear disc parts. both threads are in this forum. Quote Link to comment Share on other sites More sharing options...
matfield Posted June 5, 2013 Author Share Posted June 5, 2013 I've read both of those conversion threads Western, very informative!! I was really looking for some confirmation of my own opinions, that it was something you wouldn't want to do for the same reason you stated above, the weight rating. Out of interest, what is a disco axle rated to? Quote Link to comment Share on other sites More sharing options...
western Posted June 5, 2013 Share Posted June 5, 2013 for a 300tdi Discovery the max rear axle weight is 1650kg, on a standard 110 no heavy duty suspension, it 1850kg, on a 130 it's 2200. so a Disco rear would be overloaded, hence the rear salisbury & on later vehicles a beefed up P38 type rear axle. Quote Link to comment Share on other sites More sharing options...
ajh Posted June 6, 2013 Share Posted June 6, 2013 Though the weight rating is in reality just the diff strength. The same housing with a 4-pin diff is rated higher (or so I understand it) so if you're looking for an alternative for the rear a newer 110 Rover axle would be my choice as it doesn't drag as low as the Sals will. Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted June 6, 2013 Share Posted June 6, 2013 But try finding a later Rover axle for sensible money! That said, it's also easy to get "nickel and dimed" when assembling the parts to do a Salisbury conversion. Quote Link to comment Share on other sites More sharing options...
