carlosbeldia Posted June 8, 2013 Share Posted June 8, 2013 Good day. Is there a part number for the loom connector with the 4 pins? can we buy it from new? Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2013 Share Posted June 8, 2013 Drop a PM to PaulMc he may be able to assist, Quote Link to comment Share on other sites More sharing options...
PaulMc Posted June 8, 2013 Share Posted June 8, 2013 I don't have the in-tank fuel pump/sender connector; but, as they are a BMW connector, they can be sourced from a BMW dealer.The BMW description and part number is – 4-way female housing – 61 13 8 367 076 (superceding – 61 13 8 367 072)If you need them, replacement terminals and wire seals can be bought from BMW (I don't have the current part numbers); but, I do have some of the terminals and wire seals, which I sourced through AMP (Tyco).AMP (Tyco) make these connectors (as well as several other types of connector) exclusively for BMW, they won't sell them to you direct, you have to go through a BMW dealer.However, some of the terminals and wire seals used in these connectors, are also used in some other commercially available Tyco connectors; so, these are available through Tyco distributors. If you're only replacing a damaged connector housing and don't need new terminals or wire seals; then, this is how you release the terminals from your existing connector – The connector housing has a sliding lock plate on it's front, once this is slid open, the terminals can be pushed out from the front to the rear (they can be quite resistant to moving) – don’t pull on the cable, as it will probably pull it out of the terminal.Locked (lock-plate slid over to the left) –Opened (lock-plate slid over to the right) –. Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2013 Share Posted June 8, 2013 i knew you would know where to get on, Quote Link to comment Share on other sites More sharing options...
PaulMc Posted June 8, 2013 Share Posted June 8, 2013 The BMW connector looks like this - . The colour (Water Blue) denotes that it is a neutral or 'zero coded' (code Z) connector. i.e. - It has no keyways, is universal and will mate with all other connector 'codes' in the series. . Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted June 8, 2013 Author Share Posted June 8, 2013 Thanks a lot, tomorrow I'll make the unlock and fix..... Quote Link to comment Share on other sites More sharing options...
Dave10101 Posted August 6, 2013 Share Posted August 6, 2013 Hi. Do you still have pins & seals available for these plugs (& possibly a plug to)?Thanks Dave - Mob: 07788600194 Quote Link to comment Share on other sites More sharing options...
