Tom17 Posted July 4, 2013 Share Posted July 4, 2013 As above! Been given one that works with no diagrams or anything just about 100mm of cable out of them but I can extend that etc just not sure what to wire it to? Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted July 5, 2013 Share Posted July 5, 2013 fit it where you like, most people put it by the back door, it will need a fused live from somewhere positive/battery, via a relay, you then need a fused switch supply to the relay. Or if you are only using a low power bulb and its one with a built in switch then you just need a fused supply from the battery, you can earth back through the body Mike Quote Link to comment Share on other sites More sharing options...
Tom17 Posted July 5, 2013 Author Share Posted July 5, 2013 fit it where you like, most people put it by the back door, it will need a fused live from somewhere positive/battery, via a relay, you then need a fused switch supply to the relay.Or if you are only using a low power bulb and its one with a built in switch then you just need a fused supply from the battery, you can earth back through the body Mike Thanks mike Would I get everything I need from halfords or similar? Where is best place to get the 12v from directly from battery or? Quote Link to comment Share on other sites More sharing options...
easytiger Posted July 7, 2013 Share Posted July 7, 2013 Direct from the battery is probably easiest but you must put an in line fuse holder as close as you can to the pos terminal and it goes without saying that the fuse must be of a lower rating than the cable. Mark Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 7, 2013 Share Posted July 7, 2013 Depending what year it is you may have a permanent live spare into the right rear light box. It's a purple wire for trailer accessories. If you get a wiring diagram for your model and also do a google search for worklight wiring it'll give you a starting point. Quote Link to comment Share on other sites More sharing options...
