Nigelw Posted July 11, 2013 Share Posted July 11, 2013 Need to get a set of aircon hoses but for a 200Tdi Disco LHD they are rare as rocking horse ploppy plop plops. What alternatives are available in terms of having them made up? I have the condenser unit and they were cut off just at the bulk head when it was removed so I have the steel pipes to couple to there but need to find a solution for the rest. Would a domestic A/C service dept be able to make them up do you think? Any ideas? Quote Link to comment Share on other sites More sharing options...
Bushpig110 Posted July 12, 2013 Share Posted July 12, 2013 If you know part numbers use Google you may well get lucky and find old stock, Any good A/C company should be able to make the pipes just whether you want to pay the price Quote Link to comment Share on other sites More sharing options...
Nigelw Posted July 12, 2013 Author Share Posted July 12, 2013 The numcat links seem to be broken and I can't seem to find a comprehensive list of hoses to work out which I would need for a LHD 200Tdi? Might just be easier to get them made and heaven to betsy with the cost. Quote Link to comment Share on other sites More sharing options...
greenmeanie Posted July 12, 2013 Share Posted July 12, 2013 Find your nearest Parker Hannefin dealer. They will usually be under hydraulics in the yellow pages.They'll have all the fittings, o-rings, hose you need. take the old fittings in ands show them to the bloke behind the counter and he'll provide you with replacements plus some bulk hose. Go home, install the fittings and route the hose. A good rule is one straight fitting plus one angled if required. If you do two angled take a pen and draw a line along the fitting and onto the hose so they can clock them properly. Return to the place and they'll crimp them up. It's not difficult or expensive and you get the exact hose to fit your vehicle. Quote Link to comment Share on other sites More sharing options...
western Posted July 12, 2013 Share Posted July 12, 2013 Need to get a set of aircon hoses but for a 200Tdi Disco LHD they are rare as rocking horse ploppy plop plops.What alternatives are available in terms of having them made up? I have the condenser unit and they were cut off just at the bulk head when it was removed so I have the steel pipes to couple to there but need to find a solution for the rest. Would a domestic A/C service dept be able to make them up do you think? Any ideas? this one works, LHD Discovery 200tdi air con hose diagram http://lrcat.com/#32/4/45445 Quote Link to comment Share on other sites More sharing options...
