perv Posted July 22, 2013 Share Posted July 22, 2013 Good evening all, I need help! Can anyone please tell me where I can get one of these, it is the stub axle distance piece as fitted to a MkIII wide track trailer. Any help would be much appreciated Thanks Ash Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 22, 2013 Share Posted July 22, 2013 Might be worth asking JasonG4110? Quote Link to comment Share on other sites More sharing options...
pete3000 Posted July 23, 2013 Share Posted July 23, 2013 is it a critical part?, i.e is is a load/bearing surface or just a distance piece? if it is not case hardened, or precision you could get one knocked up on a lathe as it doesn't look too complicated. Pete Quote Link to comment Share on other sites More sharing options...
perv Posted July 23, 2013 Author Share Posted July 23, 2013 Might be worth asking JasonG4110? May be worth an ask Ross. is it a critical part?, i.e is is a load/bearing surface or just a distance piece? if it is not case hardened, or precision you could get one knocked up on a lathe as it doesn't look too complicated. Pete On the series hubs that are called distances pieces but they only keep the hubs spaced away from the stub axle so machining is possible Pete, ta Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 24, 2013 Share Posted July 24, 2013 Got a drawing with some sizes on Ash? Quote Link to comment Share on other sites More sharing options...
SWB Posted August 1, 2013 Share Posted August 1, 2013 LR Series have a section of spares for the Sankeys. Very helpful people. SWB. Quote Link to comment Share on other sites More sharing options...
