RoverRepair29451 Posted August 28, 2013 Share Posted August 28, 2013 Doing a dashboard pull-off in a few days, anybody know of any places where I can find detailed info on the pull of? Redoing the main wiring harness. Not looking forward to it. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 29, 2013 Share Posted August 29, 2013 No info in your post on what age of Discovery, but if it's a 300Tdi age (94-98) it's dead easy, I had a curly-up dash on mine years ago and changed it in about 4.5 hours. From memory, everything you need to know is on the RAVE CD, it looks like a nightmare job but really isn't. It's pretty obvious what has to come off to make it possible, and then it's really just a case of finding all the retaining bolts etc, and there aren't that many. Basically you take off the steering wheel and its plastic shroud, instrument binnacle etc, glovebox, airbag if fitted, fuse box cover, all the heater controls, radio and surround, and take out the centre tunnel console, and then there are about 8 bolts that hold the frame of the dash in, take those out and it more or less lifts out. It's easier with two, but I did mine by myself on a Saturday morning. Quote Link to comment Share on other sites More sharing options...
PaulN Posted August 29, 2013 Share Posted August 29, 2013 Not something I've done mself yet but will have to at some point so I saved a link to read up on when the time does come - thanks to 'DiscoStu' - this may help you too? Linky Quote Link to comment Share on other sites More sharing options...
teabag Posted August 29, 2013 Share Posted August 29, 2013 You'll know when your getting there when it looks like this.. looks like brain damage to me Quote Link to comment Share on other sites More sharing options...
JimDay Posted August 31, 2013 Share Posted August 31, 2013 If on a Disco1 When you have the dash out check for rust in the lower corners of the screen caused by lack of seam sealer Quote Link to comment Share on other sites More sharing options...
