David Sparkes Posted July 9, 2014 Share Posted July 9, 2014 They would seem to be very 'powerful' pieces of metal, containing much magic. If I've identified the number correctly, and obviously I think I have :-) it is FRC3147. I'll let you look up the price for yourself, I need a sit down. Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted July 9, 2014 Share Posted July 9, 2014 Rob, I fitted Stage One Hub/stub axle assemblies as well, so I think the slightly larger diameter of the Series hubs in the vicinity of the hub seal would require that the oil catcher may need to be bored out to suit. Fitting the double lip twin spring oil seal from coiler hubs would require a sleeve be made for the series hub because the coiler seal has a smaller outside diameter. Quote Link to comment Share on other sites More sharing options...
Rob_K Posted July 10, 2014 Author Share Posted July 10, 2014 Thanks again for the updates. My Series 2a seems to be a bit "non-standard" around many areas, so I will have to check to see if the wheel hub assemblies are standard, or "modified" in some way. Has anyone documented the necessary modifications to retro-fit these oil seals? A step-by-step photo sequence and description would be very useful. Cheers, Rob Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted July 10, 2014 Share Posted July 10, 2014 When the oil catchers are fitted the hub outside is machined parallel and has a groove in the turned section to stop the oil running along the hub as it has to drip off where it still inside the catcher. Quote Link to comment Share on other sites More sharing options...
xychix Posted July 31, 2014 Share Posted July 31, 2014 This is exactly the operation my newly acquired 109 series III will need on front (and maybe back) Quote Link to comment Share on other sites More sharing options...
