elmscroft Posted September 5, 2013 Share Posted September 5, 2013 Hi All, A friend is in need of some help. This is what he sent me. Essentially, any time I'm driving over about 60 mph and apply the brakes - even lightly - I get judder and delayed braking, like the ABS is coming on (although the ABS light doesn't come on). Recently had front left hub replaced after wheel bearing failed, so may be associated? Local garage couldn't find any codes to follow up with, and mechanical inspection didn't reveal anything obvious. Any suggestions welcome. Thank you. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 5, 2013 Share Posted September 5, 2013 Re-seat the ABS sensors, gently tap with a soft hammer should do it. Quote Link to comment Share on other sites More sharing options...
Disco DJ Posted September 5, 2013 Share Posted September 5, 2013 Presume all lights (especially abs) come on with ignition and then go out? If lights are working it "shouldn't" be abs related!? Dave Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted September 6, 2013 Share Posted September 6, 2013 Where did the front hub come from ? I have had one DII in where the customer bought hub off E bay, turned out it had the wrong number of teeth on the reluctor ring - only found when I scoped front and rear hubs together... It would also make the ABS come on like yours,also would make the TC active under wide throttle openings up to 60 mph. Didnt store any faults in the SLABS ecu either as it thought it was doing the right thing. Quote Link to comment Share on other sites More sharing options...
bear Posted September 9, 2013 Share Posted September 9, 2013 Have you had the discs checked for runout? Griff Quote Link to comment Share on other sites More sharing options...
