C18RCH Posted September 12, 2013 Share Posted September 12, 2013 I'm currently overhauling my transfer box. I bought an overhaul kit complete with paper gaskets but I looked on ashcrofts website last night and they use sealant type gasket. Since I have some in the shelf anyway I'm now wondering which is the best to use and why? Cheers, Rich Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted September 12, 2013 Share Posted September 12, 2013 I have used both where they were applicable, no problems its a personal choice I think, go with what you like/prefer. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 12, 2013 Share Posted September 12, 2013 For some locations in the transfer box particularly it does matter, because it affects bearing pre-load. For example the rear bearing cover plate for the input gear. The mating surface between that and the t-box casing had a paper gasket on early models and used RTV type sealant on later ones. But you must use what is fitted to the box you have as the pre-load for the bearing (which is set by the choice of a spacer shim on manufacture to allow for machining tolerances in the t-box casing) depends on this thickness being maintained. I discovered this when I was messing about with input gears and bolted the cover plate on "dry" to test fit and it locked the bearings solid. Re-fitted with correct paper gasket in and all was well. Follow the workshop manual and all will be well. Quote Link to comment Share on other sites More sharing options...
