Reiny Posted September 16, 2013 Share Posted September 16, 2013 I need to replace the front crankshaft oil seal (found a small puddle of oil in the bottom part of the timing case). How do I remove the sprocket? How do I put it on again and more importantly, what tips do you recommend to remove and replace oil seal? engine's a 300tdi. Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 16, 2013 Share Posted September 16, 2013 Have you read through the Tech Archive? Mav Quote Link to comment Share on other sites More sharing options...
Reiny Posted September 16, 2013 Author Share Posted September 16, 2013 Yes I have but so far all I found was a small part in the cambelt removal guide and it didn't specify how to do the job. Quote Link to comment Share on other sites More sharing options...
western Posted September 16, 2013 Share Posted September 16, 2013 timing case has to be removed to replace the front crank oil seal, this thread shows how to do it http://forums.lr4x4.com/index.php?showtopic=42950 Quote Link to comment Share on other sites More sharing options...
Reiny Posted September 16, 2013 Author Share Posted September 16, 2013 Thanks Western. The link is for a 200tdi. The 300 is significantly different but at least now i know that the sprocket can be levered out and tapped back into place. Quote Link to comment Share on other sites More sharing options...
western Posted September 16, 2013 Share Posted September 16, 2013 D'oh, sorry, seems we don't have a crank frount oil seal change thread, that 200tdi one is the closest. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted September 17, 2013 Share Posted September 17, 2013 This might help. Looks like a 200Tdi but says 300Tdi in the title also Quote Link to comment Share on other sites More sharing options...
