ejparrott Posted October 18, 2013 Share Posted October 18, 2013 Has anyone got a dimension for the hole centres on 109 1-ton spring hangers? A PO of my 109 replaced the rear spring front outriggers with standard spring hangers, left the front axle the same and lef the 1-ton shackles on the rear. As a result my axle is sitting at the wrong angle. I'd like to put it back to standard by replacing the hangers. Richards were initially happy to sell me the right bits, but then decided that the welding was too difficult and that I should replace the whole outrigger and everything. Not very easy to do with mine. Anyway, I have a friendly welder mate, so I was going to built my own. Just short of the information for the hole centres. Had a look in the green book but seems to be no information. Thanks Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted October 18, 2013 Share Posted October 18, 2013 I would guess that its the same figure as the difference between std and 1 ton shackles centres. I will measure them in a bit when i go outside. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted October 18, 2013 Share Posted October 18, 2013 MOD 109" rear shackles 5 1/8" ctrs Std civvy 109" rears 4"ctrs. from memory the spring hangers have a larger difference than 1 1/8" between the 2 sets of holes. Over to somebody else with a 1 ton/wd spec 109". Quote Link to comment Share on other sites More sharing options...
Michele Posted October 18, 2013 Share Posted October 18, 2013 I can try and take a measure during the weekend if I remember! Quote Link to comment Share on other sites More sharing options...
ejparrott Posted October 19, 2013 Author Share Posted October 19, 2013 That would be great if you could Quote Link to comment Share on other sites More sharing options...
Michele Posted October 19, 2013 Share Posted October 19, 2013 It this what you need to know?if so, the distance I measured is 39mm. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted October 20, 2013 Author Share Posted October 20, 2013 Perfect, Thank you very much! I'm thinking of getting some 6mm steel drilled to the right centre's and using a spring bolt to hold them in the right place and weld them to the exisiting standard mounts. Then cut away the original gussets for the standard mounts, and replace them with new ones for the longer hangers. Looks like more than yours maybe has, but I can't help thinking a bit of strengthening lower down can't be a bad thing. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 19, 2015 Author Share Posted March 19, 2015 To bring this up to date, the old civvy spring hangers are now gone... Replaced by a pair of Richards' proper military/1-ton hangers... Welded in by my rather tall friend who managed to work his way into some rather awkward spots to get them glued on... And now we look the biz... I've just got some new 1-ton dampers for her, have a feeling those on her were also civvy.... Unfortunately I could only get Britpart....they'll (hopefully) do for now until she really starts getting some use, then I'll upgrade all four to something decent. Next up is to replace the little bent plate that sits behind the bump stop...no idea where that went to! Richards want all of £3 for it so it's not worth me trying to draw it up and get someone to make it. Then...bump-stops, or more precisely the extension that bolt to the chassis to facilitate fitting normal bump-stops. I looked up some pictures, not keen on paying over £100 for a set, so I'll make my own. Would I be right in assuming that they are also the magic 1.5" tall, to match the centers of the spring bolts? Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 20, 2015 Author Share Posted March 20, 2015 So yes, 1-ton dampers are about 2" longer than standard, and yes it did have civvy dampers fitted.... However....new problem.... Any suggestions?? I admit I was hoping.....managed to order the wrong bolts...ordered shackle bolts instead of damper bolts for some reason.... Quote Link to comment Share on other sites More sharing options...
ballcock Posted March 21, 2015 Share Posted March 21, 2015 Why not grind it flat drill & tap into it? Use a bolt and a penny washer. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 24, 2015 Author Share Posted March 24, 2015 I've been pouring penetrating oil into it since Friday, several goes with the blowtorch getting the end red hot, got an 8.8mm holes drilled into the end of it...no movement yet, but it will come out! Have had rust dust dropping out the end when I've been wacking it though, seems it's in the middle where it's being held. Quote Link to comment Share on other sites More sharing options...
