streetrover Posted October 22, 2013 Share Posted October 22, 2013 Hello all! Quick question for everyone...on a 3.9, 4.0 or 4.6 litre motor with a distributor, what are the ignition settings? How many degrees before TDC should I set the timing AT IDLE? What is the overall advance (at say 3500rpm)? Thanks, Bob Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 22, 2013 Share Posted October 22, 2013 3.9 was 6 BTDC, unsure on others. Or 12 on LPG I tend to run 10 on mine cos I can adjust it in MegaTune without affecting the overall map advance by something as clunky as twisting a dizzy Quote Link to comment Share on other sites More sharing options...
streetrover Posted October 23, 2013 Author Share Posted October 23, 2013 Actually I was requesting the numbers to replicate the distributor advance curve in tunerstudio for my MSExtra 4.0 litre. So 6 degrees BTDC at idle. What then, is the maximum advance at WOT? Bob Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 23, 2013 Share Posted October 23, 2013 Have you downloaded a map for a RV8? There are loads out here, and if you give your engine spec to Nige (Hybrid from Hell) he will have a map suitable to get you running. I too have a 4.0, but can;t get to it's maps at the moment, of I would post it... Quote Link to comment Share on other sites More sharing options...
streetrover Posted October 26, 2013 Author Share Posted October 26, 2013 Sent a PM to Hybrid from Hell asking for map. Maybe I'll get lucky and he's got something that's just "plug and play!" Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 26, 2013 Share Posted October 26, 2013 And I have answered sir - and have moved to the MS Forum !Nige Quote Link to comment Share on other sites More sharing options...
