Johannadine Posted October 26, 2013 Share Posted October 26, 2013 Can someone Please help me with the wiring for the Ignition coil and the Petrol pump. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted October 26, 2013 Share Posted October 26, 2013 Coil is not related to ECU for injection and pretty sure fuel pump isn't either, anything specific you want to know? Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted October 26, 2013 Share Posted October 26, 2013 http://forums.lr4x4.com/index.php?showtopic=86353&p=742039 Quote Link to comment Share on other sites More sharing options...
Johannadine Posted October 26, 2013 Author Share Posted October 26, 2013 we took the fuel injection out and we put the carburetors on need to know how to do the wiring Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted October 26, 2013 Share Posted October 26, 2013 Have you swapped the fuel pump? The ignition is independent of the ECU. Disconnect it and apply an ignition +12V to the coil. Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted October 26, 2013 Share Posted October 26, 2013 What type of vehicle are you talking about, I did this to my 1986 Rangy, the ignition is independent on my Rangy, the EFI fuel pump will be more of a concern, you will have to fit a fuel pressure regulator, preferably a adjustable one to sort the flow of the pump, or you could just buy a carburettor electronic fuel pump which Land Rover used on the later carb jobbies, its a bolt out/in replacement no modifications, it just flows less than the EFI, you still need to regulate it. I am waiting for my long range tank so I can assemble my Rangy to see what I need to do to get the pump working the original way the EFI worked, that part I still need to figure out. Quote Link to comment Share on other sites More sharing options...
