LT230 callopsable washer
skauldy
If you are referring to the collapsible sleeve on the centre shaft, they are collapsible for a reason.
You should always fit a new one if you have rebuilt the box. The idea is that you tighten the nut on the back, until a certain torque is achieved to turn the shaft. As the nut is tightened the sleeve collapses.
I believe on later models, or even some rebuild kits, this part has been replaced by a fixed length spacer.
