Question regarding diff set up and Puma axle retrofit
  • 2 weeks later...
Just a final update to this post,
Regarding rear prop length and gearbox position the location of the 300tdi box has certainly moved in relation to the 200tdi. You were all right :) As a result a Td5 prop will not fit a 200tdi setup with a puma style rear axle. In the end I decided to have a bailey morris hd prop made up to the correct length. A bit more expensive than a td5 prop but it has nice big spiders and sliding joint which is nice.
Out of interest the working length for the rear prop of this set-up is 1120mm. So a Td5 prop is slightly too long and a 300tdi prop slightly too short.
Thanks for everybody's help in getting all this sorted.
