bernie Posted November 27, 2013 Share Posted November 27, 2013 Jack up one front wheel of 110, and I can turn wheel and front prop whilst handbrake is on and in low/high ratio, is this ok, or is it a transfer box fault. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted November 27, 2013 Share Posted November 27, 2013 I think it's ok - if the gearbox is in neutral then the propshaft would turn the internal differential in the transfer box and thus the output gear of the mainbox, wouldn't it? If you engage diff lock, or have the main box in gear then I don't think the prop should be able to move. G. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted November 27, 2013 Share Posted November 27, 2013 Sounds OK... if you had DIfflock engaged then the transfer box diff locks and so the prop shouldn't turn. However the wheel itself may still spin as the front diff is open. Quote Link to comment Share on other sites More sharing options...
bernie Posted November 27, 2013 Author Share Posted November 27, 2013 Ok, that's cleared it up, thank you. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted November 27, 2013 Share Posted November 27, 2013 Just remember that if you jack up the back wheels, you effectively have no hand brake, I always chock both sides of the wheels on the axle I'm not jacking! Quote Link to comment Share on other sites More sharing options...
