isbjorn Posted December 16, 2013 Author Share Posted December 16, 2013 Do I have to empty the transferbox or can swap the gasket without? Quote Link to comment Share on other sites More sharing options...
Eightpot Posted December 16, 2013 Share Posted December 16, 2013 The oil level is normally above the level of the drive flange, so when you pull it out to change the seal you will get half a litre of oil on the floor/on your shirt/in your eye. you don't need to drain the box completely, just take around a litre out and that should be fine. Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2013 Share Posted December 16, 2013 or put the vehicles rear end on ramps or axle stands with front end still on the ground to tilt the oil away from the flange area. Quote Link to comment Share on other sites More sharing options...
