jackmac Posted December 20, 2013 Share Posted December 20, 2013 Hi all, Having some problems with my wipers that I can no longer ignore due to the amount it's been raining! Firstly, the passenger side wiper arm keeps falling off the splines. I see there is a little metal clip there to hold it on, tried bending it out a bit but that doesn't seem to have worked very well. Am I looking at a new wiper arm there? It doesn't hit the screen seal when wiping, just falls off after about 30 wipes! The only other thing I could think of was to drill through the arm and the splined end of the shaft, then out a split pin through to stop it coming off? Secondly, the drivers side wiper shaft is moving outwards. I can get a photo if it would help, but the whole shaft slips out away from the bulkhead, eventually causing the wiper arm to rub on my roll cage. Wearing the wiper arm and the cage away, and the extra resistance means the wiper can only move about 10cm reducing visibility a bit!! Am I looking at a new wiper wheel box to fix that? I've taken the dash top off to have a look, but I can't see what to adjust to stop this happening? Quote Link to comment Share on other sites More sharing options...
western Posted December 20, 2013 Share Posted December 20, 2013 this might help you fix it http://forums.lr4x4.com/index.php?showtopic=57813 Quote Link to comment Share on other sites More sharing options...
jackmac Posted December 23, 2013 Author Share Posted December 23, 2013 1 wiper down... the passenger 1 was washed off the car on a very flooded road so that's 1 new wiper arm required! I'm not sure that link helps diagnose what's going on with mine at the moment. I'll try and get a photo of what it's doing tomorrow morning before heading out for a new wiper arm Quote Link to comment Share on other sites More sharing options...
western Posted December 23, 2013 Share Posted December 23, 2013 probably need a new adapter which has the splines on it & now you need a new arm/blade as well, Quote Link to comment Share on other sites More sharing options...
cackshifter Posted December 24, 2013 Share Posted December 24, 2013 Careful whose arm you buy - the little clip on allmakes ones seems to drop out for a pastime. This is a case where its probably worth going genuine. Quote Link to comment Share on other sites More sharing options...
jackmac Posted December 24, 2013 Author Share Posted December 24, 2013 Just treated myself to some genuine splined adaptors, arms and wiper blades (partly because they only had genuine in stock). Merry xmas to my truck! Quote Link to comment Share on other sites More sharing options...
