defender dinky Posted December 30, 2013 Share Posted December 30, 2013 hi, seen this on the forum somewhere but cannot find it, can anyone give me info or diagrams, I need to convert a 100 amp alternator to fit the V belt pully, I have a split charge system and need a bigger ampage, dd Quote Link to comment Share on other sites More sharing options...
western Posted December 30, 2013 Share Posted December 30, 2013 just remove the multi vee pulley & bolt the single v pulley on, Quote Link to comment Share on other sites More sharing options...
defender dinky Posted December 30, 2013 Author Share Posted December 30, 2013 cheers western, do I use a 300tdi alternator, I have a disco 200tdi in my defender 90 Quote Link to comment Share on other sites More sharing options...
western Posted December 30, 2013 Share Posted December 30, 2013 I have a Discovery 300tdi 100amp Marelli on my Defender 200tdi engine, been fitted for over 10 years, just upgrade the charge feed wire from Alternator to starter solenoid/battery positive terminal, standard 200tdi alt was a 45amp or 65amp. you may need to turn the rear of the casing so the 2 bolt lugs match the engine bracket & the adjust link fits the inner upper bolt hole, Quote Link to comment Share on other sites More sharing options...
defender dinky Posted December 31, 2013 Author Share Posted December 31, 2013 thanks again western, i'll get it sorted now, have another problem now, batteries went flat charged them up over night fully charged now but I got egnition lights on but nothing when I turn the key not even a click from starter anyone know why cheers dd Quote Link to comment Share on other sites More sharing options...
jackmac Posted December 31, 2013 Share Posted December 31, 2013 Have you checked them with a volt meter, or is it just the charger that says they are fully charged? Quote Link to comment Share on other sites More sharing options...
defender dinky Posted December 31, 2013 Author Share Posted December 31, 2013 hi checked with volt meter showing 13.15, dd Quote Link to comment Share on other sites More sharing options...
Tanuki Posted December 31, 2013 Share Posted December 31, 2013 o hi checked with volt meter showing 13.15, dd Is that the basic voltage on the batt. terminals, or the voltage with a load? Try this: Turn ignition on; don't start engine; turn headlamps on; leave for 5 minutes. _THEN_ measure the voltage on the battery terminals. Modern batteries can go from being good to being dead in a day or so - specially if they have been seriously discharged. An "unloaded" voltage-test tells you nothing about the battery's ability to do anything useful. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted December 31, 2013 Author Share Posted December 31, 2013 hi have done what you said the battery dropped down to 12.30 thanks dd Quote Link to comment Share on other sites More sharing options...
defender dinky Posted December 31, 2013 Author Share Posted December 31, 2013 thanks everybody sorted it the wire had come off the starter motor dd Quote Link to comment Share on other sites More sharing options...
