Hi folks,
My 95 110 has a bang (or loud SNAP) in it that I just cannot find. When you go over a bump I get a bang, that sounds and feels like it is right under my feet. My front prop is new and greased. Just did a rebuild on the motor so checked mounts.... look good. I jacked up the drivers side and have some play in that wheel and bearing. It seems to only happen when one side of the truck is going up/down in relation to the other side. (mostly when right front is going up over a bump)
While checking the trany mounts, it looks like one had moved at one time, but has not moved while checking and does not appear to be moving now..... Broken shock/Spring/Shaft/............??????
Thanks to all & Happy New year!
