JeffR Posted January 22, 2014 Share Posted January 22, 2014 Fired up the V8 today (low compression 3.5), to get it up to running temp (need to check emissions for MOT), went into the house and had a cup of tea and checked emails. Forgot about the bloody thing. Nipped out about an hour later and there's high-pressure steam screaming from the header tank - bloody radiator fan hadn't kicked in (melted connector as it turned out), Now the radiator was just about empty, so lefteverythingto cool down and wandered off to sulk. When refilled and run backup to temp there don't appear to be any probs, with now rewired fan it sits at temp with no fuss.... Whats the chances of everything being ok? Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted January 22, 2014 Share Posted January 22, 2014 Being a 3.5, it's got maximum chances of being ok, and being on tickover it won't have got THAT hot especially seeing as it was on tickover and it's cold outside. I let mine overheat on tickover once off roading, similar fan problem, was doing some winching then BOOOOOSH steam cloud lol But yeah it was ok, see how you go! Quote Link to comment Share on other sites More sharing options...
JeffR Posted January 22, 2014 Author Share Posted January 22, 2014 way my bloody luck runs at the moment..... spent half the day trying to remove a snapped 13mm cobalt drill from blind hole. Quote Link to comment Share on other sites More sharing options...
smallfry Posted January 22, 2014 Share Posted January 22, 2014 Its a 3.5. It will be absolutely fine, worst that will happen is the head gaskets might go if they are the tin ones. Big bore engine would most likely be fooked. Quote Link to comment Share on other sites More sharing options...
