pgrbff Posted January 26, 2014 Share Posted January 26, 2014 Is there anywhere on the body the original colour code is recorded? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted January 26, 2014 Share Posted January 26, 2014 No, LR never stamped it on the VIN plate, have a look through here http://coachpainting.info/ click on the links in left hand side for non metallic or metallic paint depending on what you have, the years of use are on right hand side of the new page that opens. note a lot of colours have 2 or more names if used on various LR model ranges. Quote Link to comment Share on other sites More sharing options...
pgrbff Posted January 26, 2014 Author Share Posted January 26, 2014 Thanks. It appears only Alpine white, Savarin white fit the bill, although there seem to be several variations in the codes which is confusing. Quote Link to comment Share on other sites More sharing options...
western Posted January 26, 2014 Share Posted January 26, 2014 Chawton white is/was a 300tdi white, a mate had one. use the 3 letter codes on the left of list. Quote Link to comment Share on other sites More sharing options...
paulnb57 Posted January 26, 2014 Share Posted January 26, 2014 If its the original colour, your nearest main stealer should be able to tell you the colour from your vin number... Paul Quote Link to comment Share on other sites More sharing options...
western Posted January 26, 2014 Share Posted January 26, 2014 no colour code in the VIN, but a dealer will be able to find out from production records at LR the correct info. Quote Link to comment Share on other sites More sharing options...
pgrbff Posted January 26, 2014 Author Share Posted January 26, 2014 Thanks for all your help. Paul Quote Link to comment Share on other sites More sharing options...
paulnb57 Posted January 26, 2014 Share Posted January 26, 2014 Thats what I meant, but the production records are accessed from the VIN..... Quote Link to comment Share on other sites More sharing options...
Mustardman Posted January 26, 2014 Share Posted January 26, 2014 Just an afterthought, when I took the door card off I found the build sheet stuck to the inside with all sorts of useful information including the colour code. Thought I'd mention it in case you had a door related job you could bring forward. Quote Link to comment Share on other sites More sharing options...
