blacksmithbob Posted February 2, 2014 Share Posted February 2, 2014 Hi all, my hazard warning switch's internal lamp has packed in. Can it be replaced? and how does the switch come out? Many thanks Quote Link to comment Share on other sites More sharing options...
PaulMc Posted February 2, 2014 Share Posted February 2, 2014 Hi all, my hazard warning switch's internal lamp has packed in. Can it be replaced? and how does the switch come out? Many thanks 2002 TD5 ??? If so, the easiest way to remove it without damaging it, is to push it out from the rear. As for the switch's bulb, it's not listed in Microcat for the 2002-2006, or 2007 -> Defenders (so most dealers tell you it's not replaceable and try to get you to buy a complete new switch). It is replaceable, it's listed for the 300Tdi Discovery-1 Hazard Warning Lights Switch (which is essentially the same switch, but vertical instead of horizontal), its part number is - STC1205 - BULB & HOLDER ASSEMBLY, CLEAR http://www.rimmerbros.co.uk/Item--i-STC1205 . Quote Link to comment Share on other sites More sharing options...
blacksmithbob Posted February 3, 2014 Author Share Posted February 3, 2014 Paul, thanks for your very helpful reply. At 50 odd quid for a new switch that's a result! Many thanks again. Quote Link to comment Share on other sites More sharing options...
western Posted February 3, 2014 Share Posted February 3, 2014 linked to tech archive for this info. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted February 3, 2014 Share Posted February 3, 2014 For anyone who needs an STC1205 bulb and holder for their hazard warning lights switch, you may be interested in this eBay listing -BRAND NEW RANGE ROVER P38 HAZARD WARNING LIGHT SWITCH - AMR2691 - LAND ROVERThese switches are £1.00 each + £0.71 postage (to the UK)Each switch has 2 x STC1205 bulbs in it If you buy an STC1205 bulb and holder from a dealer, they're £3.40 each (incl. VAT). Quote Link to comment Share on other sites More sharing options...
