Lewis25 Posted February 9, 2014 Share Posted February 9, 2014 Hi there, I have a disco v8 engine which is currently going into my series 2a. It will only run when the return pipe is pinched. There is an electric fuel pump which ticks away when it is not pinched but then when i pinch the return line the ticks become slower, (more pressure) and it will run nicely. Any ideas of a more permanent solution to this? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 10, 2014 Share Posted February 10, 2014 Are you on carbs or EFI? Sounds like you are running an EFI system on a carb pump, but by pinching the fuel line it brings the pressure up to the required... Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted February 10, 2014 Share Posted February 10, 2014 +1 think you have a fuel pressure problem, you will have to upgrade to cope with the EFI Quote Link to comment Share on other sites More sharing options...
Lewis25 Posted February 10, 2014 Author Share Posted February 10, 2014 No its running SU carbs! Thats why i think its weird! Thanks for the replies Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 10, 2014 Share Posted February 10, 2014 Sounds like a weak pump then... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 11, 2014 Share Posted February 11, 2014 Or a leaky something or other in the carb? Can you tell I don't do carbs Quote Link to comment Share on other sites More sharing options...
