justustwo Posted March 9, 2014 Share Posted March 9, 2014 hi all this is one of a few posts i am going to put on today ...its defender work weekend ..hub seal and swivels already in progress. I have a Madman engine monitoring system in my 93 200tdi standard defender and been in a few months (use to have it in an old series) but till now have not had the coolant temperature connected as i want to keep the original LR coolant gauge connected AS WELL. I thought I might be able to put a standard inline coolant pipe with sender boss in where the bypass hose is on the stat housing but theres not enough space (to keep it easy). I thought the bypass hose would be good as it would give the true engine temp rather than in the rad top hose after the stat as this will only give true engine temp when stat is open .yes??? cant really easily get a 'T' piece into original stat sender and would then be a bit away from the coolant flow so could get cold spot. ok does anyone know where a point on the block I can insert a VDO sender(1/8 npt..can also use adapters to suit). Otherwise i thought get a boss put on the copper(?) pipe going along top of head to the heater...Does that always shows true engine coolant temp ??? last place i could think is if I drill & tap the thermostat hosing in the point on the picture?? any help or hints?? thanks all Andrew Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 9, 2014 Share Posted March 9, 2014 Back of the head where it feeds the heater, thats where mine is and I believe that gives true engine temp. Top Rad hose certainly doesn't Quote Link to comment Share on other sites More sharing options...
Nigelw Posted March 9, 2014 Share Posted March 9, 2014 The steel pipe is the bypass pipe and should give accurate temp reading regardless of stat status. Quote Link to comment Share on other sites More sharing options...
western Posted March 9, 2014 Share Posted March 9, 2014 the steel pipe on side of cylinder head IIRC is the coolant return from the heater, so it won't give you a true coolant temp reading as the heat can be blown into the cab. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted March 9, 2014 Share Posted March 9, 2014 the steel pipe on side of cylinder head IIRC is the coolant return from the heater, so it won't give you a true coolant temp reading as the heat can be blown into the cab. See I always get them two mixed up Quote Link to comment Share on other sites More sharing options...
western Posted March 9, 2014 Share Posted March 9, 2014 Nige -- the thermostat bypass hose is item 7 in http://lrcat.com/32#32/4/45514 for discovery 200tdi engines or item 17 in http://lrcat.com/#31/4/53138 for defender 200tdi engines. Quote Link to comment Share on other sites More sharing options...
