elbekko Posted April 2, 2014 Share Posted April 2, 2014 Yes, but if you got the proper version (the EXE), it has an index for easy navigation. Quote Link to comment Share on other sites More sharing options...
jibbyman Posted April 2, 2014 Author Share Posted April 2, 2014 Will try and get a proper version ,thanks for all the advice. Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted April 4, 2014 Share Posted April 4, 2014 Disco 2 don't have one to the g/box like Defender, sorry my bad. The earth from the battery runs to the bottom of the alternator bracket, you can reach it easy from the bottom. Then the obvious short one the the body at the battery. I would suggest a quick way to see if you have a earth concern is to use a set of jumper leads from the battery earth put one lead on the engine in a good spot, and the other one to the body on a good spot and see if the fan concern goes away. Quote Link to comment Share on other sites More sharing options...
jibbyman Posted April 5, 2014 Author Share Posted April 5, 2014 Thanks RANGY35 will give that a go .cheers Quote Link to comment Share on other sites More sharing options...
jibbyman Posted April 9, 2014 Author Share Posted April 9, 2014 Tried putting on temporary earths but no different . I can pull what ever power when stationary no problems if this helps .The lights are slightly flickering when stationary now I am presuming this is all connected ? Quote Link to comment Share on other sites More sharing options...
elbekko Posted April 9, 2014 Share Posted April 9, 2014 Yup. Is your battery clamp on tight? Quote Link to comment Share on other sites More sharing options...
jibbyman Posted April 9, 2014 Author Share Posted April 9, 2014 yes and the 3 earths off it all clean and tight .If it was the xyz switch it would play up when stationary aswell ? So when moving output is dropping and the gearbox ecu is sensing this ? Quote Link to comment Share on other sites More sharing options...
elbekko Posted April 9, 2014 Share Posted April 9, 2014 Did you check the positive clamp? Have you checked if there are any big power draws? Starter stuck, wire chafed, ...? Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted April 9, 2014 Share Posted April 9, 2014 What is your alternator doing? Please test without load( everything off) take reading at idle and at 2000 rpm. Then do same tests but put all the loads on and I mean all, aircon full speed and coldest setting, rear heated screen, all lights on and high beam, heated seats. Quote Link to comment Share on other sites More sharing options...
jibbyman Posted April 9, 2014 Author Share Posted April 9, 2014 checked starter ok .At idle 14.45 v ,2000 rpm 14.45v under load 12.83 v.Just a thought could something pull more volts while driving or perhaps the belt slipping ? Would there be more pressure on the belt ? cheers lads Quote Link to comment Share on other sites More sharing options...
jibbyman Posted April 12, 2014 Author Share Posted April 12, 2014 Connected a multimeter through cigarette lighter today and drove around with just rear demise on .After about 10 minutes it went into limp home mode but the voltage not drop below 13.97 v . Should I just replace xyz switch ? Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted April 16, 2014 Share Posted April 16, 2014 The 12,8V on full load is not good, should be 13V at least, or higher. How good is your battery? It seems that way at the end of this, the xyz switch may be the go. Quote Link to comment Share on other sites More sharing options...
jibbyman Posted April 17, 2014 Author Share Posted April 17, 2014 Will start the search for a cheap one.The battery is quite new 12 months . Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted April 17, 2014 Share Posted April 17, 2014 I think you need to take your Discovery to a decent recommended LR independant.Flickering lights are not caused by the WXYZ switch.Replacing it without proper diagnosis is an expensive gamble.Better to pay for a couple of hours expert diagnosis and get the job right. Quote Link to comment Share on other sites More sharing options...
jibbyman Posted April 18, 2014 Author Share Posted April 18, 2014 Yes ill have to could do with a approved list on the site ,how about it guys. Quote Link to comment Share on other sites More sharing options...
