oneten110 Posted October 19, 2006 Share Posted October 19, 2006 Does anybody on here run a WOLF? with the twin air intakes. If so would you be willing to describe the route of the underbonnet air trunking for me please. Are the intake hoses from the 2 opposite sides connected to each other before they get to the air filter housing, or does the air filter housing have two intakes? Any information gratefully received. Cheers Quote Link to comment Share on other sites More sharing options...
western Posted October 19, 2006 Share Posted October 19, 2006 From the left & right wing air intakes to a common water catcher/drain canister [as per standard 300Tdi's] & 'T' junction connector & then 1 hose to standard air cleaner housing. Quote Link to comment Share on other sites More sharing options...
JST Posted October 20, 2006 Share Posted October 20, 2006 as ever Ralph is right, its pretty std trunking except from the drivers wing it goes to a Y piece with the afroementioned drain at the bottom. other wing entry has a pipe upto the same Y piece then 1 pipe to the air filter. bear in mind that most of them are getting snorkels fitted now, if not all already done, which means they should be blanking off/removing the 2nd wing feed which should therefore mean there are alot of Y pieces and wing to Y pipes around. Sodbury - bet a few turn up there. Quote Link to comment Share on other sites More sharing options...
western Posted October 20, 2006 Share Posted October 20, 2006 Most of that was a guess, but I do know how a 300Tdi's air hose route, just thought it was a T connector instead of a Y one. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 20, 2006 Share Posted October 20, 2006 A bit like this: B) Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted February 27, 2007 Share Posted February 27, 2007 JST - the near-side inlet is blanked but none of the trunking/connectors are removed. The off-side has the outer cover removed (and binned) and the snorkel fitted to that. Soooo, there may be a few off-side outer covers knockiing about, but none of the other stuff as it all stays in place...... Well, thats how it is with all the we've I've fitted anyway..... Quote Link to comment Share on other sites More sharing options...
