Souster Posted May 23, 2014 Share Posted May 23, 2014 Hi, The indicator on my 96 90 is playing up. Noticed it since i bought it 3 weeks ago and its fine turning left. But turning right, as soon as the wheel is turned even very slightly its canceled immediatley. Infact i barely can indicate right! Not sure it this is also MOT fail issue. But regardless its quite annoying. Do i require a new stalk? Or is it something else? Cheers Quote Link to comment Share on other sites More sharing options...
western Posted May 23, 2014 Share Posted May 23, 2014 sounds like the cancel ring on the steering wheel & it's counterpart on the main stalk switch assembly is incorrectly set, you need to remove the steering wheel & check the [normally blue plastic] ring on the switch assembly, it should have a moulded arrow head on it which should point to the left [9 o'clock position] with the 2 slots at 12 & 6 o'clock. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted May 23, 2014 Share Posted May 23, 2014 Didn't you move the steering wheel??....... Me thinks that's where your issue is..... Quote Link to comment Share on other sites More sharing options...
Souster Posted May 23, 2014 Author Share Posted May 23, 2014 Didn't you move the steering wheel??....... Me thinks that's where your issue is..... Thanks. And yeah i did adjust the steering wheel but it was like it when i bought it (without me messing with the steering wheel). Cheers too western Quote Link to comment Share on other sites More sharing options...
Souster Posted May 23, 2014 Author Share Posted May 23, 2014 Despite moving the steering wheel, will it still be okay to do what Western has suggested? The problem was there before i adjusted the steering wheel Quote Link to comment Share on other sites More sharing options...
western Posted May 23, 2014 Share Posted May 23, 2014 Yes, the cancelling part of steering wheel is a seperate item number 2 in http://lrcat.com/#31/4/53722 & cab be moved so the 2 prongs are at top & bottom when the wheel is correctly fitted. Quote Link to comment Share on other sites More sharing options...
Souster Posted May 23, 2014 Author Share Posted May 23, 2014 Yes, the cancelling part of steering wheel is a seperate item number 2 in http://lrcat.com/#31/4/53722 & cab be moved so the 2 prongs are at top & bottom when the wheel is correctly fitted. Perfect again. Your knowledge is incredible. Another cheap fix, thanks a lot western Quote Link to comment Share on other sites More sharing options...
Souster Posted May 25, 2014 Author Share Posted May 25, 2014 sounds like the cancel ring on the steering wheel & it's counterpart on the main stalk switch assembly is incorrectly set, you need to remove the steering wheel & check the [normally blue plastic] ring on the switch assembly, it should have a moulded arrow head on it which should point to the left [9 o'clock position] with the 2 slots at 12 & 6 o'clock. Just checked this, and its already fitted exactly how you say it is. If thats okay, does it mean its the stalk thats the issue? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 25, 2014 Share Posted May 25, 2014 Check that the clamping ring holding the stalks to the Column is not broken. Mo Quote Link to comment Share on other sites More sharing options...
Souster Posted May 25, 2014 Author Share Posted May 25, 2014 Check that the clamping ring holding the stalks to the Column is not broken. Mo Thanks Mo will do, applying the indicator left is fine. Applying right is abit like the spring has gone (figure of speech) and it wont hold itself up Quote Link to comment Share on other sites More sharing options...
western Posted May 25, 2014 Share Posted May 25, 2014 other than the bit Mo has mentioned maybe the wire spring inside the switch has broken. Quote Link to comment Share on other sites More sharing options...
Souster Posted May 25, 2014 Author Share Posted May 25, 2014 I'll have a look guys. Wouldnt that clamping ring make the indicator wobble though? Failing what you have both suggested ill have to buy a new one then? Thanks to you both Quote Link to comment Share on other sites More sharing options...
western Posted May 25, 2014 Share Posted May 25, 2014 Yes, if the clamp is broken, mine is at the blocks where the screw/nut is, the switch will move slightly when it's operated, on the column end is a notch which the switch unit should sit in to stop it moving big amounts. Quote Link to comment Share on other sites More sharing options...
Wonkey Donkey Posted August 9, 2020 Share Posted August 9, 2020 I had the same issue when turning right after installing a brand new indicator stalk unit. Found the issue to be the rubber cover on the stalk had just enough resistance in it to prevent the stalk latching quite fully when turning right. Hence the stalk would kick back into its centre position. I just fiddled with the rubber grommet cover till it offered less resistance to the stalk and now it's working correctly. Quote Link to comment Share on other sites More sharing options...
