jjojjas Posted October 24, 2006 Share Posted October 24, 2006 I have just recieved a pair of forward facing rear load area seats for the 110. the seats seem fine, however the belts.... where have you mounted the floor seat belt anchor point? the "female" end of it? please don't tell me I need to remove the fuel tank to do this...or I'll be needing a new fuel tank also..... Jas Quote Link to comment Share on other sites More sharing options...
white90 Posted October 24, 2006 Share Posted October 24, 2006 I have to make up an anchor point as the rear floor on mine has a large hole where the belt would mount. can't see how you'd fit yours without getting above the tank though on a 110 Quote Link to comment Share on other sites More sharing options...
jjojjas Posted October 25, 2006 Author Share Posted October 25, 2006 I suspect you may be correct........ But I may weld the nut onto a spreader plate and slide it from the rear crossmember gap into place above the tank then tighten it from the top. Nothings straight forward is it....... Jas Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 12, 2006 Share Posted November 12, 2006 Had some in the 110 but took them out as they were surplus to my requirements and someone else wanted to play with them. The lower mounts were bolted through the rear floor with spreader plates.... They must have passed the previous years MOT.... Seems simple enough. Unfortunately I did not remove them... See old piccie.... Looks like a tank out jobbie though !! Neil Quote Link to comment Share on other sites More sharing options...
western Posted November 12, 2006 Share Posted November 12, 2006 Neil, that's Jas's own website so I think he might know about it Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 12, 2006 Share Posted November 12, 2006 I've slightly edited my post to be more helpful !! Quote Link to comment Share on other sites More sharing options...
western Posted November 12, 2006 Share Posted November 12, 2006 makes sense now Quote Link to comment Share on other sites More sharing options...
